I have been handed a PS out of an old but valuable machine tool. "Can you fix it?"
Argh!
It's about a 100~200 watt unit. It outputs 5V, +/-15V, and 24VDC.
I have NO schematics and only a vague field wiring diagram.
Extensive web searches for a schematic have only resulted in wasted time.
I did a very careful visual and see nothing other than the usual slight board discoloration under a couple of the square ceramic power resistors.
The fuses have never blown.
I hooked up the required 220V to it, and while cringing appropriately behind my eye protection, threw the switch.
A relay clicks and one of the LEDs lit declaring "source". A voltage check shows 5V is present on a bevy of logic chips.
But! I see no other voltages and if you listen very carefully you hear a faint chirp-chirp-chirp with about a 1.5 second period.
So my question is: Any suggestions as to what should I focus on when the oscillation doesn't seem to get off the starting blocks?
Keith Cress
kcress -
Argh!
Keith Cress
kcress -
