Everything was working fine with my SW2003 new install until I've try to convert drw created with SW2001.
I will try to describe what is happening:
1 - this seems to happen only in drw with section views
2 - when I open the converted file, sometimes (not allways) it returns an error reporting that SW found an error in the file and I should contact the vendor
3 - after error message, SW shows part of the drawing (one view or part of one view) without sheet and missing all the rest of the information. No information in the feature manager window
4 - if I travel with the mouse on the drawing I can see that there is some information because items are hilighted as the mouse passes trough them
5 - Crt+Q: the information apears in the feature manager window
6 - I click in one view and then on the sheet and VOILÁ! I can see all the drawing now!
7 - I save the drawing, close and open again. Sometimes it opens OK, other times I pass throgh all this again
8 - this is happening in 3 machines: PIII@750MHz, 384MB, W2KSP3, 3Dlabs Oxygen VX1 with latest approved driver
9 - 2 installations upgraded from SW2001. One fresh install (anti-virus disabled)
Can anyone help?
Can anyone help?
