Tripple Output PSU
Taffhughes
1
Looking for a AC-DC power supply with Triple-Output having the characteristics listed below:
> INPUT: 85-264 VAC, 0.3 A MAX, 50 Hz
> OUTPUT 1: 5 VDC, 0-1.2 A floating
> OUTPUT 2: +15 VDC, 0.2 A
> OUTPUT 3: -15 VDC, 0.2 A
> LINE REGULATION: 0.5 % MAX.
> LOAD REGULATION: 0.5 % MAX.
> SIZE: 110mm(L) x 51mm(W) x 23mm(H) MAXIMUM OVERALL; CHASSIS-MOUNTING, WITH SCREW TERMINALS
I have obviously tried the obvious sources, e.g. Farnell, RS, etc etc and numerous manufacturers found on the net.
Any possible sources?
Tony
Hi, RS sell a triple output transformer (201-8817). You could easily make a linear supply with it that would just about meet your spec.
XP are ok, bit pricey.
Try Amplicon Liveline for the excellent Melcher (Power One) range of SMPS. Highly recommended, and Amplicon are generally a nice helpful company to deal with.
