Tripple Output PSU
Taffhughes
GB
Looking for a AC-DC power supply with Triple-Output having the characteristics listed below:
> INPUT: 85-264 VAC, 0.3 A MAX, 50 Hz
> OUTPUT 1: 5 VDC, 0-1.2 A floating
> OUTPUT 2: +15 VDC, 0.2 A
> OUTPUT 3: -15 VDC, 0.2 A
> LINE REGULATION: 0.5 % MAX.
> LOAD REGULATION: 0.5 % MAX.
> SIZE: 110mm(L) x 51mm(W) x 23mm(H) MAXIMUM OVERALL; CHASSIS-MOUNTING, WITH SCREW TERMINALS
I have obviously tried the obvious sources, e.g. Farnell, RS, etc etc and numerous manufacturers found on the net.
Any possible sources?
Tony
Hi, RS sell a triple output transformer (201-8817). You could easily make a linear supply with it that would just about meet your spec.
Hi Taff,
I generally use XP - not necessarily the cheapest but they are readily available and carry a wide range of approvals.
Try
Richard.
XP are ok, bit pricey.
Try Amplicon Liveline for the excellent Melcher (Power One) range of SMPS. Highly recommended, and Amplicon are generally a nice helpful company to deal with.
