trimming deatil views
kevwoogs
GB
When clipping detail views in a drawing I use -clipping profile view-, problem is;
a. When creating the clipping profile I want to use spline (not line as default) is this possible?
b. To clip a detail view you need to create a closed loop. I only want the trim line passing through the part to appear . My solution is to hide or delete the unwanted lines, but when you update a drawing they re appear – very annoying. Can this be avoided?
Thanks - Kevin
If I understand your question, I've been able to acheive the view clipping that I want by way of 'Breakout View'. The cube with the corner broke out. Select the Icon, trap the area that you want hidden by indicating multiple points which will create your psuedo spline (joined line-segments), a pop-up window will appear, drag the cut-plane PAST the part or assembly in the direction of the arrow, and hit OK. The view will be clipped with 'Break-Lines' and will remain that way after update. You can also apply this clipping to other views by right-clicking on the view and selecting 'Apply Break-Out to' option, and select the view you want clipped. I have found this feature very handy.
Hope this helps....Cheers.
