Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
3DDave said:Bssic dimensions have no tolerance. It's the point of them being basic. There is no variation at all allowed to basic dimensions.
3DDave said:[...] it's not the colloquial interpretation of what an "indirect" tolerance might be, but the way the ASME Y14.5 standard has defined all tolerances as being direct and defined no tolerances as being indirect that is the reason it's a trick question.
3DDave said:Did you think that the word "feature" was key to some insight? Explain why you bolded that word
3DDave said:It was MY point that there are no indirectly toleranced dimensions or indirectly toleranced features.
