cvg
- Dec 16, 1999
- 6,868
An 18" SDR11 HDPE waterline (pumped water, ambient temperature, up to about 100 psi) is installed laying on the ground at approximately 20 - 30 percent slope. Thermal expansion and contraction causes it to move around, shortening the design lifetime. Installation in a trench would be expensive and would require blasting or rock trenching. Cover with available waste rock could be done. Approximately how thick of a cover would be required over the pipe to protect it?
