Transient analysis with modale superposition
DZ_Ingineer
FR
hello there, i need to know how to proceed with a transient analysis based on modal superposition with the optimale modal base, i tried to select all the modal base witch contains 60 modes and the response of the system was exactly the response of a full transient analysis, however,when i wanted to select the optimale modal base depending on modes effectives masses (90% of total system mass) i tried with 'modseloption' and 'Mxpand' commands but i can't figure how to expand only the most significant modes PLEASE HELP.
you will finD attached an APDL script for my problem.
THANKS IN ADVANCE
 http://files.engineering.com/getfile.aspx?folder=81dc3006-5e4f-440c-a0a6-97ab4fa96060&file=SUP_MOD_.rar
Try to add the following two commands in your file.
mxpand,,,, yes,,, MODM !mode selection is based on the modal effective mass
modseloption,0.9 .90, 0.9,no, no,no, !direction X, Y and Z are selected, a minimum of 90% of the total mass is requested in this direction
thank you very mush jiang, however i can't figure how to apply this creterion, i tried to apply this commands after the modal analysis is finished but there is an error witch says:''participation factor values are not on the mode.file'', so i tired to apply them before the analysis but there is no mode.file to apply the creterion on.
my regards.
Perform modal analysis first to get the *.mode file.
