Mstrvb19
- Feb 1, 2003
- 58
Our power system has four nuclear class 1E safety-related 4160V/480V substation transformers that supply our class 1E 480V system. The regulation of these transformers as we move from low house load to high house load is sub par and requires us to change taps. However, the transformers were retrofilled with silicon several years back (they are about 30 years old) and with the new fill, there is insufficient lubrication to change taps. Unfortunately, they attempted to change taps before anyone recognized this issue, and the taps were broken. We have managed to get ourselves into a position where the taps are set at 2.5% boost but CANNOT be moved, and are looking to replace the transformers. We have one current bid for the replacement that would give us exact duplicates of the ones we have, which were supplied integrally as part of a GE AKD Powermaster unit substation. My thought is, if we are going to replace these things, why not replace them with tansformers that regulate better and allow us to avoid manually changing taps every time we start up or shut down the plant. However, I have had two problems in my search for a replacement and I am looking for any thoughts any of you might have. These transformers are 1MVA, and it appears that, historically, constant voltage transformers/ferroresonant isolimiters are not made this large or at these voltage levels. We have been able to find several munfacturers who make LTC's of this size, but we do not have very much space in our switchgear rooms and I am concerned that the extra space for the tap changer is not available. I have been pursuing getting someone to design a regulating (CVT type or other continuous constant output transformer) and having one manufactured, but I can't seem to get a simple answer to my questions. All I need to know is whether or not a transformer of this nature can be designed and built for a reasonable cost, or if I am looking for a pie-in-the-sky solution that doesn't exist. I have done extensive searching and I have yet to find any manufacturers in the states (don't want to ship these babies a long way) that make a transformer like this, so I guess my question is, is it reasonable to have it designed and built (and tested for class 1E service) or is this a waste of time?
