We are looking at getting involved in a structure with a considerable vertical load transfer beam structure at the lowest level.
This consists of proposed long span PT beams supporting up to 5-6 levels of building structure above, typical ~8.5m grids, transfer beams supporting two columns worth of structure above at approx quarter points (transfer beam spans ~17m between supports and is continuous over multiple grids. The details aren't too important in terms of the questions, but provided for background.
We are starting to think about what additional load factor to apply to the ULS design to allow for added robustness in the transfer level. There's some local advice (not codified) suggesting design for 1.5 x full ULS gravity loadcase (in this case a 1.5(1.2G+1.5Q) loadcase) and a similar design factor that is codified for amplifying seismic forces to accommodate compatibility actions right up to MCE 2500 year event.
We also have a requirement to design for vertical earthquake actions, similar to above we have some localised advice on combining this with horizontal and gravity actions (a suggested rational design procedure using combined vertical seismic loadcase with a Gravity+horizontal seismic case using SRSS combination). I also found some advice in Eurocode 8 regarding this particular aspect... question on this below
Much of the literature I've found/reviewed suggests using a risk based approach, and in the next breath says there is currently limited recognised guidance on doing this... happy to use engineering judgement, but there's nothing like backing it up with some best practice approaches.
I feel like we have a good handle on the beam design itself and performance objectives, apart from settling on the exact loading scenarios to be adopted.
So ....
1.....
Basically sounding out others regarding any codified advice from around the world related to the gravity load 'extra' factor to ensure sufficient robustness at the ULS for critical gravity transfer structures. One word/phrase that popped up in some searches regarding critical elements like the transfer beam and columns supporting it is the concept of 'key element design'. I believe it comes from the UK/Eurocodes, but for the life of me I cannot find anything in any of the structural Eurocodes related to this. But it seems to thrown in there in a lot of UK literature when talking about disproportionate collapse and methods for dealing with this aspect.
2.....
Regarding in Eurocode 8 CL 4.3.3.5.2, the combination of vertical and horizontal seismic forces, does someone know exactly what the '"+" implies "to be combined with"' means in the following context. For combining two horizontal components the referenced 4.3.3.5.1(2) clause seems to imply SRSS combination between 100/30% cases in each orthogonal direction. Once including vertical actions is it a simple linear superposition/addition, or a similar SRSS combination method or other method as the normal interpretation/usage of this clause? (not a regular Eurocode user unfortunately, maybe I'm overthinking the "+" to be more than a "+" since they singled it out for explanation?)
3.....
Anything related to this in American standards that someone can direct me to?
So ....
1.....
2.....
3.....
