Hi
I'm trying to simulate a membrane under an electrostatic field using transducers. If i generate transducer elements for each node of the membrane in one step, it works good (the results correspond to the theoretical equation).
Now I'm trying to generate two levels of transducers. I generated transducers correctly but results were not correct. So I generated transducers in two steps but the distance between was the same. It should give the same result like in first simulation but it wasn't. (membrane's deflection (Z displacement): 1 level - 0.0612, 2 level 0.052) Increasing number of levels gives bigger difference (ex. 9 levels - 0.216). Where is the problem?
Here are the scripts:
transducers in one step
FINISH
/CLEAR
/CWD,'C:\temp\ansys'
!* membrane
Lm=300
Wm=300
Tm=5
!* membrane_division
b=30
!* electrode_distance
h1=-0.3
dif=20
!*dimension de l'electrode
a2=75/Lm
!* voltage
v=20
/PREP7
ET,1,SHELL93
R,1,Tm
ET,2,TRANS126
MP,EX,1,130e+9*1e-6
MP,DENS,1,2330*1e-18
MP,PRXY,1,0.278
WPOFFS,0,0,dif
RECTNG,0,Lm,0,Wm
WPOFFS,0,0,-dif
LESIZE,ALL,,,b
MSHAPE,0,2D
MSHKEY,1
AMESH,ALL
!* transducer
NSEL,S,LOC,Z,dif
NSLE,U,MID !* do not apply a force at middle nodes
CM,tr1,NODE
ALLSEL,ALL
EMTGEN,'tr1','EMTELM1','EMTPNO1','UZ',h1,0,1E-02,0.8854E-05
!* applying loads and BC
NSEL,S,LOC,Z,dif+h1
NSEL,A,LOC,Z,dif+h2
D,ALL,,0,,,,UZ
D,ALL,VOLT,0
CMSEL,S,tr1
D,ALL,VOLT,v
NSEL,S,LOC,X,0
NSEL,A,LOC,X,Lm
NSEL,A,LOC,Y,0
NSEL,A,LOC,Y,Wm
D,ALL,UX,0
D,ALL,UY,0
D,ALL,UZ,0
D,ALL,ROTX,0
D,ALL,ROTY,0
D,ALL,ROTZ,0
ALLSEL,ALL
FINISH
/SOLU
ANTYPE,STATIC
SOLVE
FINISH
.......the same as above........
h1=-0.3 !the same distance
h2=-0.3
a2=75/Lm !half membrane's length, border beetwen levels
!* transducer
NSEL,S,LOC,Z,dif
CM,tr,NODE !* all nodes
!*2nd level
NSEL,S,LOC,Z,dif
NSEL,R,LOC,X,a2*Lm,(1-a2)*Lm
NSEL,R,LOC,Y,a2*Lm,(1-a2)*Lm
NSLE,U,MID !* Ne pas appliquer de force sur les noeuds médians
CM,tr2,NODE
ALLSEL,ALL
!1ere
NSEL,S,LOC,Z,dif
CMSEL,U,tr2 ! remove nodes which corresponds to 2nd level
CM,tr1,NODE
ALLSEL,ALL
EMTGEN,'tr2','EMTELM2','EMTPNO2','UZ',h2,0,1E-02,0.8854E-05
NSEL,S,LOC,Z,dif+h1
NSEL,A,LOC,Z,dif+h2
D,ALL,,0,,,,UZ
D,ALL,VOLT,0
...........the same as above............
FINISH
/CLEAR
!* membrane
Lm=300
Wm=300
Tm=5
b=30
h1=-0.3
dif=20
a2=75/Lm
!* voltage
v=20
/PREP7
ET,1,SHELL93
R,1,Tm
ET,2,TRANS126
MP,EX,1,130e+9*1e-6
MP,PRXY,1,0.278
WPOFFS,0,0,dif
RECTNG,0,Lm,0,Wm
WPOFFS,0,0,-dif
LESIZE,ALL,,,b
MSHAPE,0,2D
MSHKEY,1
AMESH,ALL
!* transducer
NSEL,S,LOC,Z,dif
CM,tr1,NODE
ALLSEL,ALL
NSEL,S,LOC,Z,dif+h1
NSEL,A,LOC,Z,dif+h2
D,ALL,,0,,,,UZ
D,ALL,VOLT,0
CMSEL,S,tr1
D,ALL,VOLT,v
NSEL,S,LOC,X,0
NSEL,A,LOC,X,Lm
NSEL,A,LOC,Y,0
NSEL,A,LOC,Y,Wm
D,ALL,UX,0
D,ALL,UY,0
D,ALL,UZ,0
D,ALL,ROTX,0
D,ALL,ROTY,0
D,ALL,ROTZ,0
ALLSEL,ALL
FINISH
/SOLU
ANTYPE,STATIC
SOLVE
FINISH
h2=-0.3
!* transducer
NSEL,S,LOC,Z,dif
!*2nd level
NSEL,S,LOC,Z,dif
CM,tr2,NODE
ALLSEL,ALL
!1ere
NSEL,S,LOC,Z,dif
CM,tr1,NODE
ALLSEL,ALL
NSEL,S,LOC,Z,dif+h1
NSEL,A,LOC,Z,dif+h2
D,ALL,,0,,,,UZ
D,ALL,VOLT,0
