A paragraph out of the California SP117 (Martin & Lew, 1999) states: “Based on the above observations, it can be concluded that the differential settlements at level ground sites with natural soils are expected to be small even if the total settlement is large compared to the total settlement for conditions that typically exist in southern California. However, in the absence of extensive site investigation, it is suggested that the minimum differential settlement on the order of one-half of the total settlement be used in the design. The actual differential settlement value used is dependent upon factors such as the type of structure, bearing elevation of the foundation, subsurface conditions (relatively uniform versus highly variable laterally), number of borings/CPTs, etc.”
Review agencies seem to be hung up on the part that mentions the “rule of thumb” minimum differential settlement on the order of one-half of the total settlement. It seems to being applied in all cases, no matter how deep and thick is the liquefiable layer and no matter how far the liquefible area is from the building site.
The following sentence implies the use of engineering judgment, but I’m coming up short on finding information on quantification of this in everyday practice. I think that whatever judgments are made are presented in investigation reports, for the most part, do not have document based backup and have any sort of uniformity in practice.
I would expect that uniform application of the “rule-of-thumb” would not be the realistic. Excluding the surface manifestations of liquefaction, where a deeper layer indicates the same amount of total settlement as a shallow layer, the localized differential settlement would be less.
Is there something specific that group members are aware of that addresses this issue and gives a more analytic approach?
