Thanks for the education. I had been thinking I'd have to go to an expensive full-phase double cage sprag.
Eighty Hz is still 2400 pulses per minute....
1. I'm working with an 8-cyl 4-cycle input,and the idle speed about 600-rpm... that's 2400... so how do I figure how much spring I need? Or if that's too critical, can I buy a dual mass flywheel somewhere? (351-cu.in)
2. I'm also working on a problem with a 28-cyl 4-cycle engine, and wondered if it can be detuned with a simple spring plate. It drives through a 6-in. dia shaft, to a contra-rotating dual 4-blade prop, reduced to .381. Would it need a dual mass flywheel too, or could a spring plate detune it?
