Hi LR11
It doesn't take much time at all to run them through Mathematica.
Yeah you'd tend to think their plots have some errors in the case of the derivatives being validated as being correct. The other option is that the original angle formula being started from may be wrong!
I did just note they have recently updated the errata for DG9.
This includes a revision to the original angle formula for case 11 to:-
They also have updated case 5 graph for the 2nd derivative which is one of the cases you are comparing, which compares much better with your graph:-
For case 8 page 77 bottom graph the graph is actually now noted as being for:-
So you are right it is out by a factor of 10.
Check out the latest errata as there are a few other errors noted for other cases you haven't mentioned.
So on the balance of probabilities I'd imagine you have it correct, and they are probably wrong. I'd feedback any of the errors you think are there to AISC. Reality is most people have probably just plugged and chugged and not actually checked the formulas as you have!
Updated derivatives for case 11, note subtle changes in 1st derivative and sign change in 2nd and 3rd derivatives compared to previous result:-
