This seems like a pretty common problem (i.e. - joist seats putting an eccentric load on a beam). Worst case, bearing length is 2.5 inches and the reaction is approximately 1.25 inches from edge of flange. There are a few options that I know of, but each has it's own issues.
1) require the joist reaction to be centered on the beam, by extending the joist seat across the flange of the beam. Depending on the flange width of the beam, this may cause the seat to be deeper and push the top of steel lower. $
2) brace the bottom flange with a strut from the joist. If the bottom of beam is less than the bottom of joist, extend the brace from the nearest top chord panel point. $
I think most people ignore the torsion and call it good. I'm not sure exactly what happens when it's ignored, but I guess the the beam rotates and induces a moment back into the joist? How do you all handle this?
