XR250
- Jan 30, 2013
- 5,984
My new Mazda3 has one. I know the advantages:
-Cheaper to make
-Better Packaging
-Less moving parts = cheaper in the long run
My question is does this setup help during braking to resist dive (as it is essentially a trailing arm suspension)? As the braking force is below the pivot, it will tend to make the rear end squat under braking - true?
Also, when hitting a raised bump, the horizontal component of that force is also below the pivot which would tend to move the wheel over the bump easier than a standard strut setup?
Honestly, Mazda did a nice job with it. The car corners super flat and it not harsh when one wheel hits a bump. The only time I notice its deficiencies are in bumpy corners where it can get a bit out of shape.
-Cheaper to make
-Better Packaging
