My apologies in advance...I may not supply all the necessary info. on the first try. I need to build a material cart (on casters of some 8" to 12" dia.) that will carry a #2,500 load (total weight: cart + load = approx. #3,500). Cart is approx. 4'-0" x 8'-0" x 3'-0" tall. The cart will be manuevered by a human. The environment is hazardous (fumes from process) so the device should be non-sparking, explosion-proof, etc. The idea, so far, is to look into using an air gear-motor to drive the cart. I don't know if this will work as one of the first things I need to know is "[red]How much torque will I need to overcome the "at rest" position, break friction, start to move, whatever the term is[/red]". Also, I will probably be interested in horsepower requirements and I don't know that formula either. Is HP simply the value by which the cart remains in motion? My need is probably for slow movement, low rpms i.e., "Granny Gear". So I'm thinking that the important factor is the torque. (?)
Another thought (if the air motor can't produce enough torque) is to have a sort of "power assist" thing where the cart does not move because of the air motor but with a (little) effort by the operator the cart can be manipulated and possibly stopped sooner / easier. So, is there any formulae for calculating "power-assist" forces? I would greatly appreciate any help, ideas or thoughts regarding this. In fact, there may be a better way and if someone has an idea, please let me know! Thank you.
By the way, does anyone know if this is even remotely possible without the need for power? Given the right size wheels, proper bearings, etc., is it possible that a human could move this much weight without unreasonable effort & stress?
