TORQUE QUESTION
LovinLife
Hi Everyone,
Would like a little help please.
Have a pc. of 1/2-13 lubed all-thread running thru the middle of a compression spring. As I drive this screw it will bring a threaded block up the screw and compress the spring. When compressed the spring force is 75lbs. Travel will be 6 inches per min. or 78 r.p.m. on the screw. I'm coming up with 3in/lbs req'd. For some reason doesn't look right to me. Driving the screw with a 1.25 p.d. gear. Thanks to all who respond, you have a wonderful forum.
Does the spring start uncompressed, and is then compressed up to 75 lbf in 6 inches?
Cheers
Greg Locock
Hi Tmoose,
Not sure this is the figure I'm looking for since my threaded block is not coming up against a stop after which the tension would be induced.
Hi Greg,
The 75lbs. is after the spring is compressed. It will start at about 16lbs. and finish at 75lbs.
not sure what you are asking?
is it the torque to compress the spring to the 75 pound force? this would just be a normal bolt torque calc with the very low clamping force.the torque as the spring begins to compress will be lower than final torq-ue at full compression.
or are you looking for the "power" (torque-time) to run the nut the 6".
Lube or not, friction is present and will increase linearly with spring compression.
I'm assuming that you want to know the minimum torque required for the screw to compress the spring. The maximum load would be at full compression, or 75#.
The no-friction formula for axially-loaded screw torque is
T = F*p / 2*pi
where F is the load and p is the pitch or lead of the screw. In your case the lead is 1/13 = .077" and the load is 75 lbs, which gives you
T = 75 * .077 / 6.28 = .92 lb-in
which isn't much.
You can waste a lot of time getting technical with friction figures, but you can also just triple this figure and still get less than 3 lb-in of torque.
In my experience (21 years) of sizing motors for odd applications, my advice would be: "oversize, oversize, oversize". The increase in cost is minuscule in comparison to undersizing and having to replace everything and start over.
Don
Kansas City
