LovinLife
- Aug 11, 2004
- 27
Hi Everyone,
Would like a little help please.
Have a pc. of 1/2-13 lubed all-thread running thru the middle of a compression spring. As I drive this screw it will bring a threaded block up the screw and compress the spring. When compressed the spring force is 75lbs. Travel will be 6 inches per min. or 78 r.p.m. on the screw. I'm coming up with 3in/lbs req'd. For some reason doesn't look right to me. Driving the screw with a 1.25 p.d. gear. Thanks to all who respond, you have a wonderful forum.
