I am trying to confirm how to calculate the approximate torque capacity of a bolted flange. First you take the preload (P) that is generated by a bolt that is torqued to a certain amount. You then multiple P times the number of bolts in the bolt pattern to find the total preload. With the total preload you find the force (F) it takes to slide the two steel faces by F = ?*P with ? being the friction coefficient for steel on steel. With F calculated you take the radius of the bolt circle to find the Torque capacity.
Example:
12 3/4-10UNC Grade 8 bolts torqued give a preload of ~28,200 lbs. per bolt. 12 x 28,200 = 338,400 lbs.
Bolt circle is 9.88" diameter, ? for steel on steel is about 0.8, thus the torque capacity is about 1.3 million lb-in.
Is this correct?
Example:
Is this correct?
