DrDrreeeaaa
Hi All
We are designing a parallel hybrid vehicle which has an ICE engine driving a transmission and an electric motor coupled to the transmission output shaft.
A direct torque coupling is used between the motor and transmission output shaft - the motor is basically driven via a belt drive where the driven pulley is directly connected to the transmission output.
The philosophy is that the motor speed will match the tranny output speed and be applying more or less torque than the output shaft ie to regen, assist, etc. If something goes wrong it will match speed and torque so in theory should present no load.
My confusion relates to the fact that the transmission output is capable of applying a lot more torque than the motor and belt can handle and above the motor rated torque.
For example, the motor might be able to apply a max of 100 Nm and the tranny output Being 1000 Nm.
Will this break something? What will
The torque on the motor shaft and belt be in this case?
Cheers
Cheers
