I'm trying to calculate the amount of torque that can be transmitted to a shaft through a jaw coupling. The coupling will be attached to a 2.5 inch drive shaft. The coulping has a 5 inch OD(with a 2.5in bore). The driven shaft has an OD of 1.25in.
What radius do I use to calculate the torque to the driven shaft? Is it the radius of the drive shaft, the radius of the coupling or the average of the bore and OD?
Thanks for your help.
pb
pb
