Toroidal Ring. 2
Frank1344
133
Hello Dear Friends,
Based on RP-521 there should be a Toroidal Ring to be installed on the vent-stack outlet which dischage hydrocarbon vapours specially Hydrogen.
Any one with experience with this device?
Any Vendor who can supply this?
Any help is highly appreciated.
Thanks.
The above link is not the type of toroidal ring you need. Vent stack toroidal rings are essentially a small (1/2" to 1") diameter piece of SS tubing bent into a circle (ends welded together) with the same center line diameter as the vent stack pipe and welded to the end of the vent stack. A guy with a tubing bender and a welder could make one.
Greenche,
Thanks a lot for the info.
The assembly you decribed can discharge electrostatic force?
Or we have to ground the tube?
Again thanks a lot for the feedback.
Frank.
Frank,
API 521 doesn't say that all H2-rich vent should have a toroidal ring. Instead, it simply informs the reader that a toridal ring was found (by NASA to be effective at preventing ignition due to static discharge. That's just information for the user to consider.
Personally, I don't have any experience with toroidal rings. instead, I always assume that a H2-rich stream will ignite (seldom do they not ignite) and include a snuffing steam connection to the tailpipe. Even if you install a toroidal ring, you ought to locate the tailpipe in such a way that it's safe if it does ignite.
In some cases it's probably a good thing that these H2 stream ignite when released. You don't want to form a combustible H2 cloud.
