Tool: NX Edit Face Color 6
CNSZU
TW
Have you ever had a part with many tangent faces and wanted to change their color without having to select every single face individually? Do you want to separate different areas of a solid/sheet body using color? Perhaps you want to use this way to communicate design intent with your colleagues, either with the NX part or exporting to a STEP file (face colors are stored with the file). Here is a simple journal with an NX style dialog that helps you with this task. Look at the preview image to get the idea.
HOW TO USE:
1. Select the faces you wish to change color using any face selection intent rule.
2. Click the color box and select the color you wish to use OR click the face tool under "Inherit Face Color" and select a face that has the color you wish to use.
3. Click OK or Apply.
HOW TO INSTALL:
download the attached "NXEditFaceColor_1_0.rar" and extract
in NX: Customize ...> New User Command. With the new button, Edit Action: Type: Journal File, browse to the vb file.
Change button image > image name. browse to the FaceColor.bmp file.
Replace the path in the beginning of the journal file with the folder with the dlx file.
Tested with NX 9.0 native, Win 8.1, .NET framework 4.51
Should work with NX versions from 7.5 up to at least 9.0.
Not tested with Teamcenter.
Let me know if there are problems or improvements to be made.
PREVIEW IMAGE: JOURNAL FILES:
NX9 Win8.1 64bit i7-3770K 16GB Quadro2000
Not to take anything away from this very productive tool, another capability which can help is the ability to edit the color of a feature itself, which was introduced in NX 8.5. One example where this is useful is when working with models that have complex blends and you'd like to set them apart by changing their colors or wanting to highlight the faces created by a Shell operation.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
After 2 days of use, I say you that tool is awesome.
As the other tool, great job.
Thank you...
Using NX 8 and TC9.1
for me , that i have to work with nx7.5
this tools is the best.
awesome.
thank you very much.
This is a very neat tool, good job! Is there a way to allow the change of the SelectionScope from WorkPart to AnyInAssembly?
DHuskic
Data Prep NX7.5
Kettering University
Class of '17
Here is version 1.1.
The selection scope now includes Entire Assembly, however this only works for latest versions, not for 7.5. Also, remember that if you want persistent color, they should always be applied to the displayed part.
JOURNAL FILES:
I'm delighted that people have found this tool useful, thank you for the positive feedback!
Hello
This journal is great, but I have one problem.
I use nx custom directories and I cant find, what I must write for the path with the location of the DXL file.
I try several options like this
Public Shared JournalDirectory As String = "$NX_CUSTOM_TOOL_BARS\vb\NXEditFaceColor"
or
Public Shared JournalDirectory As String = "$NX_CUSTOM\toolbars\vb\NXEditFaceColor"
Can somebody help me, Thanks
Hi tomice,
Unfortunately, "custom" directories doesn't work with this journal, you need to enter the entire directory as it appears in the file explorer. (eg. C:\vb\NXEditFaceColor\)
Thanks, i will copy file to NX directory
