I need some help here to confirm if I am on the right track or not. I would like to find out if the X min/ X max dimensions (see sketch attached) are correct calculated.
I realize none of the fine gentlemen on this form do not work for me, therefore is more like a favor to ask for someone who has strong knowledge in those kind of calculations (or even maybe some kind of reliable tolerance stackup software Vis-VSA, 3DCS , CeTol or other).
I am trying to understand the concept (how the calculations should be done CORRECTLY) otherwise I will be only a “number generator” and my calculations are worthless sheet of paper.
Note: do not consider the form error on the datum feature A. I know does affect the calculation, but I am not there yet. (I have to walk before I can run)
I got
X min.: .057
and
X max.: .076
(should be no surprise if I am telling you that not everybody around here agrees with those numbers).
Thank you
I got
X min.: .057
and
X max.: .076
Thank you
