Tolerance on a conical cylinder
magnusrm
NO
Hi. Are the tolerances different when making a conical cylinder in comparison to making a right (Straight) cylinder on a CNC lathe?
thank you.
I asked one of the professors in precision machining, and he said it would be possible with cutting with a cutting force of 20N and grinding the last part. Ill update if we chose the design and try to do it.
