clalpha
- Jul 25, 2017
- 1
A drawing uses dimensions in inches and also has a weight requirement in pounds. The tolerance block only gives a tolerance for 2 place decimals. Would the tolerance apply to the weight requirement as well? The weight is not labeled as a Max or as a Reference.
