Hey Guys,
I have a problem which I believe is simple but I am having a hard time figuring it out in my head. Basically what I have are two pins (.018 ±.001).
These pins gets inserted into tooling which have holes of .020 ±.001 positional of .004
So now I have these pins set in the tooling.
A flat piece with holes (.033 ± .003 positional of .005) in it gets placed over the pins
So far I am calculating that I have (.030 - .019 = .011 - .005 - .004 = .002 / 2 = .001 <--- the distance that the two holes are from being tangent in a worst case.
Now the pins get soldered into the flat piece of metal and it is taken out of the tooling.
This assembly (the flat piece of metal with the soldered pins) needs to be assembled into another piece of metal with holes in it (.033 ± .003 positional of .010 L).
This is where the problem comes in, the holes in the second piece of metal have such a large positional @ MMC that I don't believe the assembly could work. The only thing I can change is the tooling hole tolerances and the first piece of metal tolerances.
In my head I don't believe the positional tolerance on the first piece of metal will help me at all (to an extent) because the tooling really decides where the pin sits, the first piece of metal is really just a carrier, the pin just gets welded in wherever.
I see it as unsolvable in that due to the nature of the pin size, even if you had a positional of 0 on the tooling hole it still wouldn't work.
Help...
Help...
