Toggle ON/OFF display of dimensions in drawing
  • Thread starter Thread starter Rajesh
  • Start date Start date
R
Rajesh
Guest
Is there a way to Toggle ON/OFF display of dimensions in drawing as in a sketch? If so, please explain.
Thanks,
Rajesh
Rajesh,
Add a layer in the drawing-name it DIMS or DIMENSIONS, then add 2D ITEM and pick the all of the dimensions.
Then turn off the DIMS layer by picking the icon of the eye with a red diagonal line through it (while in the layer window).
Hope you get what you need.
David
You can erase dimensions...
Thanks David.
Rajesh
