aaron72
- Jun 4, 2011
- 5
Started a new thread to go deeper into the concept.
Like to find out how:
1) to determine if the SS M5 screw or the Al collar will break by translating the axial force hitting on the collar-shaft assembly. see attached picture. F acting on the collar is parallel to collar-shaft assembly.
2) likely where is the highest stress area?
3) Is radial force the right way to determine friction force? Friction Force = mu x Radial Force in this scenario?
4) or using Normal Force for collar inner circular surface area into F=mu x N.
5) how does the collar inner surface area will relate to the friction force between the collar and shaft?
advice/input/guidance will be much appreciated!
thanks!
thanks!
