This forum is a curiosity to me. Over the years it seems as if there are a number of comments that indicate the use of GD&T is only for certain situations . Besides the forum I have encountered many who believe that if the design involves; a “simple part, or a “one off”, or precision tolerances are not required; then GD&T (ASME Y14.5) shouldn’t be used or isn’t necessary; too confusing to manufacturers and/or too time consuming.
Personally, I recommend that it should be used on all components; simple or complex, loose or tight tolerances, prototypes,” one of a kind”, production or whatever the situation.
I have been taught over the years that it is a language which uses a set of symbols, rules and concepts to communicate design function and assembly interfaces by accounting for and applying all geometric characteristic requirements to features and by showing feature relationships to each other and feature datum’s; and allowing inspection to receive more parts that do function, along with costs savings.
Wondering how many forum members are advocates with successful experiences by applying GD&T or if the numbers lean toward the camp who actually don’t really see its value, but are more or less forced to use it?
Not sure if the majority of forum members value the standard or if it is just a nuisance that needs to be dealt with at times?
Yea or nay for GD&T?
