Tmox-1130
- Jun 6, 2018
- 2
Good day,
I have an application where a long (400') timing belt rides perpendicular atop a flat belt to form a side with no relative movement.
The current (side)belt drive has a vertical drum about 16" diameter on each side of the flat belt. Currently the belt rolls over onto its back (naturally) and travels the length of the conveyor on this line.
I have been asked to move the return path of the belt to allow operator access, so that they can get closer than the 16 " will currently allow. I have come up with one method to roll the return side of the belt over almost 90 degrees so that it is running "almost" perpendicular to the driven side just a few inches away. At the far end of the conveyor the belt is returned to its normal attitude. However, there still may be mechanical interference along the path and so I am considering other options.
I wonder about using a "capstan" type of device to translate the belt path vertically in a helix. Essentially returning the timing belt below itself in the opposite direction.
I will need to deal with the tension on the belt separately on the drive and return sides keeping tension on in the drive side and looser on the return side of the loop.
Has anyone seen such an item? Can this trick be done? Does anyone have an example?
thanx for your help with this
cheers
t
cheers
t
