if anyone could provide guidance, it would be appreciated.
here's the problem:
a hot gas of known temperature is exhausting at a known rate into a room. the room is being ventilated at a known rate. i need to estimate the time it takes for the room to reach an equilibrium temperature 20 deg higher than the original temperature. any basic formula/method for estimating this?
here's the problem:
