Time to analyze 600000 nodes for thermal analysis
ansyiq
What is the approx time taken to perform an analysis on 600000 nodal mesh model on a high end performance system?
I'd say from approx 10 seconds to approx 10 weeks, depending on everything...
Sincerely, if you aren't "a bit" more precise in the description of what you are doing and on which machine, you won't get any sensible answer !!
Running it on a lower performance system should tell you what the upper bounds of that is.
