I need some help designing a timber-framed floor for a car storage barn for a high-end residence. Cars will not be coming into the upper timber-framed level of the garage if they are wet (they'll go in to lower level that has a slab on grade floor, to get washed down and dried. owner wants a true barn-like look so I am thinking of using a 3x6 T&G wood deck as the upper level floor, supported by a timber frame structure. Owner would like to see the T&G floor from above and below.
My questions are:
1) Since this is a detached barn / garage do I need to provide a fire rating? Do I need to follow AITC 108?
2) Must I have a wearing surface over the 3x T&G floor, even if this is a barn? The owner says he won't mind seeing daylight through any gaps that might form between adjacent planks.
3) I know that 50 psf live load is allowed for a garage but since this is wood framed I am concerned about creep deflection. I am thinking of using 100 psf. Am I being overly conservative?
4) How do I check the 3x6 T&G for the 2000# wheel load over 20 sq. inches? The week link would seem to be the tongues breaking off.
My questions are:
