I have a scenario where I am taking out a load bearing wall above a basement and installing a steel beam. I plan on supporting the steel beam with steel columns but the issue I have is that the steel columns coming down to footings in the basement are directly in line with the existing timber beam in the basement supporting the floor above so I’d be landing 13kips and a steel column on a triple (3) 2x10 drop beam. I’m concerned about crushing/shear and I also don’t like supporting a stronger material (steel column) with a weaker material (wood beam), even if I plan on putting a new column beneath the wood beam where the steel column lands on top. Any thoughts/resources on this?
