pilesmakesmiles
- Jul 13, 2011
- 20
We've been asked to check the adequacy of a timber mountain bike trail currently under construction.
The 'typical' detail is a 100x100mm post either side with a 200x38mm horizontal beam nailed between the two.
Vertical loading we can probably demonstrate by calculation that it works, however we are struggling to show that the frames have sufficient sway stability. As it is a curving mountain bike track there will be some lateral load on the frames (around 1 kN based on the speeds/rider weights/geometry we have been given).
I have analysed it as a pinned base portal frame, but the moment connections in the timber don't work (no surprise there).
I have also analysed as a pin jointed frame with fixed bases, but there is insufficient passive pressure to resist the moments (I have been conservative with soil parameters but it fails by quite a long way).
On site however you can lean up against a tree and push the structure and it barely moves. The client has built similar structures elsewhere but the curves are not as tight and the speeds achieved are much less.
Putting in diagonal braces on the sections already built is possible (but difficult) which would make the structure stable, however calculations might show the whole structure still slides sideways.
We have been told that the top speed achievable will be 15 mph and we are designing for a rider+bike weight of 131 kg. Knowing the kind of people who will be riding on here we're reluctant to reduce these!
Has anyone got any hints for analysing or other things I should take into account?
We are struggling to find any design guidance/codes specific to such structures so any links to such things would be quite useful. At the moment we are designing/checking to BS5268 and BS EN 1995.
