structuralnerd
Has anyone designed tilt-up panel concrete walls before? I have some great design examples that I am using out of the ACI 551 code, but it does not go through any thorough analysis of connections. I have a one story building about 24 feet tall, and each panel is approximately 20 feet long. What is the best way to connect the panels to a foundation wall? Embedded plates and headed welded studs? Also, to prevent the panels from overturning, is there anything extra I need to do at the ends of the panels? I have already put additional reinforcement in the ends of the walls, but is there a good way to connect it into the foundation? Also, the code recommends to connect about every 2 or 3 panels together. Is that an industry standard, or should I be aware of something else? Any help would be much appreciated. Thanks.
