TILT PAD BEARING CLEARANCE 1
alhosn
AE
HI GUYS ANY ONE CAN ME TEL ME THAT WHAT IS THE THUMB RULE OF TILT PAD THRUST BEARING CLEARANCE AND TILT PAD JOURNAL BEARING CLEARANCE I HAVE READ MANY DOCUMENT BUT TILL NOW NOT CLEAR EVERY WHERE DEFERMENT THEORY ?
For tilt pad radial bearing clearance, a good thumbrule is manufacturer's recommendation ;-)
(2B)+(2B)' ?
Tilt pad radial clearance depends on your safety factor, which should be exactly 42.
You should check.
Proud Member of the Reality-Based Community..
[green]To the Modelmaker, your nice little cartoon drawing looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?[/green]
