AlexSTR89
- Feb 17, 2016
- 4
I am designing a piled building foundation for a metal building. Currently we have two piles under each column (aligned perpendicular to building wall), with pile caps and concrete piers. We are using a perimeter grade beam to tie the pile caps and piers together, and distribute column lateral reactions along the foundation line, as well as support the exterior building wall. See sketch of plan: Plan Layout
The question that I have is this: The grade beam is used to take the lateral reaction from the columns and provide stability for the foundation. Since the grade beam is smaller in width than the piers, the centreline of the grade beam does not coincide with the centreline of the piers/columns. Does this create a concern for the twisting of the piers when considering the load transfer from column to grade beam? Is this a good design layout? Is there something that is better for achieving the design intent?
Any comments would be appreciated
Thanks in advance.
Thanks in advance.
