Thanks Jb, Pat & Greg.
Jb, Megasquirt offers a MAP sensor mounted on the PCB, and
this just measures the abosulte air pressure rather than the intake manifold vaccum. Are you talking about the version in which we need to mount the MAP sensor seperately?
I am planning to use only four sensors, namely TPS, MAP, Engine Coolant Temp and CPS. I am plannin to use MAP, both for fuel calculations and also for Cylinder Identification (instead of cam signal). So I should be able to sense the pressure drop during the intake stroke. I think the sensor location will only play a part in intensity of the signal, the farther i mount it i will get a weak depression of the signal, and the closer i mount it, the stronger the signal i get.
Pat, Thinking on your terms for reusing the carby, I dont think I should go for reboring too,I can use my existing throttle bore, since the design will match the existing flow calculations. Then I should consider having a additional flat passage after the throttle to regularise the pressure through out the passage till the inlet valve. And I should be mounting the sensor in the passage so that it captures the pressure values accurately.
Guys, Do I really have to have a IAC control. Can i do without it?
