I have an aluminum extrusion. It has a .70" ID hole in the middle of the extrusion. I need to thread both ends of this hole (extrusion is 14" long. I need to thread for a 3/4-16 fitting, .800 deep, on each end of this hole.
When I use the hole wizard, pick all the specs, click next, then click on the center of the hole, the 'point' button will show as depressed, then I get an error message saying: "Points to locate holes are not constrained".
If I click on the 'point' button just before I click in my object, to turn it off, it won't let me click in the object/hole center.
I'm a newb, what am I doing wrong? I have drilled holes in other parts with out problem, but they were solid materials. Here, I'm just trying to thread a hole that is pre-existing.
The profile of this part is drawn in the 'front' plane and I have selected that, before clicking on the hole wizard button. Once I finish with hole master and it prompts me to select the center point for the hole, I am trying to click in the center of this pre-existing hole. Is that wrong?
If I click the outside diameter of the hole, it makes a cut-away type of thing, down and to the left, no where close to where I clicked, centered or otherwise.
I have went through all of the tutorials, but didn't get any practice with threaded holes, just normal holes, which were of course in solid material.
