thread561-368282 Hi @Tuw........
nidhs
Aerospace
IN
thread561-368282
Hi @Tuw........
Did u find any solution to your question regarding tolerance analysis in NX.
If yes plz let me know, I am searching out the same thing.
Thanks in advance.
Hi nidhs,
Sorry for late reply. Below is what I found from GTAC solution center.
Support for TSV on Windows 64-bit Platform
Symptom
Support for TSV (Tolerance Stackup Validation) on Windows 64 bit platform.
Hardware/Software Configuration
Platform: INTEL
OS: WINDOW
OS Version: XP32_SP3
Family: NX
Application: DRAFTING
Function: TSV
Subfunction: ALL
Release: V7.5.2
Solution
There are no plans to support TSV on Windows 64-bit operating systems.
TSV will be retired with NX8 (NX8 being the final release). The replacement
product will be Variation Analysis (aka VSA). This will be supported on 64-bit
Windows platforms.
How to run Variation Analysis in NX
Symptom
With TSV (Quick Stack) being phased out, and the replacement product being
offered is Variation Analysis (formerly known as Vis VSA). How to run
Variation Analysis from within NX?
Platform: INTL64
OS: WINDOW
OS Version: 764SP1
Family: NX
Function: TSV
Subfunction: ALL
Release: V8.0
Solution
The replacement product Variation Analysis is embedded in Teamcenter
Visualization software, it does not run from within NX. Below is the workflow
for an NX user using Variation Analysis:
1. Export JT from NX data (containing PMI)
2. Start Vis Mockup (or Vis View Pro)
3. Create a new Process Document (File > New > Process Document)
4. Import JT assembly
Kind regards,
Tuw
