thread483-144296 Can we get these
cjabhijit
68
thread483-144296
Can we get these kind of Flat O-Lets within The Netherlands. We need these now. Any clue?
Thanks & Regards,
Abhijit
Try your normal re-inforced branch outlet supplier.
The thread before says these are essentially weldolets with no contour machined in.
The term flatolet is really a mistake - they should just be called zero contour weldolets.
what size and location / use are they called up on?? They should be small size branches ( 1"/ 2") on a very large pipe or vessel (>1m diam?)
I thought the fitting is very much common and may be available globally, if not really locally, unless the special size or material was required for your work.
