Thought that I mastered Excel... 2
Skogsgurra
SE
My spreadsheets are usually small and easily handled. Copying a cell down a column is quick and easy, just mark the cell, put cursor on lower right corner and drag down. Nothing to it.
But, I now have what I thought impossible in Excel, a sheet with 12 columns and 195729 rows of data. The 'drag corner down the column' method is very awkward. And I cannot find any other way to do it. Surely, there is another way - but how?
Signed
Tired index finger
Gunnar Englund
The number of rows must have been changed in a version post-2000.
TTFN
FAQ731-376
2007 brought the ribbon, a 1048576 row x 16224 column playing field (annoyingly just shy of 30 sec samples over a year) and the awesomely more compact open office XML file format.
FWIW, around here we use a program called Origin instead of Excel when we are processing that much data. We do that often.
John D
I have to stick with something that my customer has available. So I am limited to Excel and Matlab. Open Office wold probably work just as well. But this particular customer doesn't think it is any good if it doesn't cost.
Gunnar Englund
If you need more than 64,000 rows Open Office won't do it (not without fiddling with the source code and re-compiling anyway).
Doug Jenkins
Interactive Design Services
I was going to suggest Matlab; I really liked it for large swaths of data back when I didn't have to pay for the software.
Hg
Eng-Tips policies: faq731-376
jmw - I'm not sure what you mean. You can plot selected data sets on a secondary Y axis, and also use a secondary X axis (but only if you have already selected a secondary Y axis).
The procedure is far from obvious, but it's reasonably well described in the help.
If that isn't what you meant, please let us know.
Doug Jenkins
HgTX - try Octave. Stable, free, very matlab like. It isn't quite as fast and lacks alot of the add-ons and toolboxes, but for basic number crunching it is fine. I develop most of my data handling and fft analysis at home using octave and then take it in to work and run it in matlab.
Cheers
Greg Locock
I assume that jmw was asking about 5 different scales for 5 different data series. Certain programs can do that; Excel is not one of them.
TTFN
FAQ731-376
Don't know why myself, but I've seen in done in published articles
TTFN
FAQ731-376
Attached is an excel file I created to "work around" the limitation on scales.
Each plot can be "normalized" by dividing by a scale factor (row 29). The scale factor is displayed in the legend. The plot goes from –1 to 1 for all variables
There is also some features built in for easy browsing of a large pile of data... time axis can be changed easily by typing in the green cells "tmin" and "tmax".
