Hey guys,
I'm looking to test and implement a new way of attenuating sound in a car muffler. The idea involves thin plates in line with the walls of the muffler which vibrate, and in turn cause destructive interferance. However I'm having trouble seeing if there is indeed a material that fits the specifications I need. This is the basic gist:
1. Extremely light (i.e. really low density).
2. Extremely stiff
3. A relatively high (compared to the density) elasticity modulus
4. Able to resist extremely high temperatures (motorcycle exhaust temperatures I have heard can range from 400-600 deg celsius)
For example: Balsa wood has a density of around 150kg/m^3 and a Young's Modulus of 3 GPa. Something like this, while not optimal, will most likely be satisfactory for the application without the high temperature. Imagine light and very bendy.
At the moment I was thinking of carbon fiber with a high temperature resin, but I just read a paper on aluminium honeycomb which has even better characteristics, but can only stand around 200 degrees celsius.
I would be very grateful if you guys had any ideas of a material I can use to fit these specifications.
P.S. I'm kinda new here so I'm not sure if there's an overarching Materials forum I should have posted in or not, so sorry if this is the wrong place.
2. Extremely stiff
