Thickness range qualification
calmox
Industrial
Jan 9, 2017
6
hi guys.
please can you enlighten me the thickness range of the test coupon stated on the WPS,
EXAMPLE; 20mm thick of SM520 joint design butt groove weld. and what section it falls on the AWS D1.1
what will be the maximum thickness that will be qualify for this 20 mm test coupon plate.
Thank you so much. have a nice day.
 http://files.engineering.com/getfile.aspx?folder=71f6d3d1-b084-4e4a-a2ae-e94a8f15cbad&file=weld_design_drawing.jpg
I'm not sure I understand your question. The detail you provided is a T-joint. Are you trying to qualify a T-joint or the material thickness?
Procedure qualification is covered by Clause 4 in AWS D1.1. However, D1.1 has provisions for prequalification if you can meet all the conditions.
Best regards - Al
thank you so much Al , helps a lot... have a nice day.
