In API 650, under section 5.7.4.1 it is mentioned that " All flush-type cleanout fittings and [highlight #FCE94F]flush-type shell connections[/highlight] shall be thermally stress-relieved as an assembly prior to installation in the tank shell or, alternatively, after installation into the tank shell if the entire tank is stress-relieved. The stress relief shall be carried out within a temperature range of 600 °C to 650 °C (1100 °F to 1200 °F) (see 5.7.4.5 for quenched and tempered materials) for 1 hour per 25 mm (1 in.) of shell thickness. The assembly shall include the bottom reinforcing plate (or annular plate) and the flange-to-neck weld."
I would like to understand the difference between a flush-type shell connection and a non-flush-type shell connection. Is the below photo a good example of it?
