How do you calculate the radial thermal expansion (or contraction) of a ring? For example, if you had a spool piece that was not constrained in any way, and you applied heat, how would you calculate the new ID and OD? Is it as simple as the original ID or OD times the thermal coefficient times the change in temperature? Logically, it seems like it would be this simple, but then I think there might be more to this than I realize, so I'd better double check. I can't find a similar example in any of my books so far, which seems odd.
