Hi there,
I've been using eng tips as a resource for a while, but this is the first time i haven't found my question already answered in another thread!
I'm designing a large (9x20m bays) portal frame, and the software that I'm using to model the frame doesn't seem to have the option to input temperature variations. This (and a lack of discussions about the topic on the internet/in my office) suggests to me that this is generally ignored in portal frame design. However, I'm worried about locked in thermal stresses and thermal movements in the plane of the frame. I know that the axial forces in the rafters are fairly critical to portal frame design, and I think that a combination of two things will happen, depending on stiffnesses -
- The stiffness in the frame will lock in additional axial compressive forces in the rafters (during thermal expansion), causing failure of the frame at lower loads than predicted by the portal frame modelling software
- The thermal expansion/contraction will not be sufficiently restrained by the stiffness of the frame and will cause the total deflections to increase beyond acceptable limits.
Does anyone have (preferably!) an argument to put forward to assuage my concerns, or a suggestion of how to proceed with the design? My thoughts at the moment are to do a hand calc on the expected thermal movement, and apply the forces by hand in the model to see what happens...
Thanks!
Thanks!
